Omni-TraceTac Cyberdeck
A cyber deck for cruising the matrix with optical augmented glass for the pre neuro-interface minded public
  • Description
  • Details
  • Files 0
  • Components 0
  • Logs 0
  • Instructions 0
  • Discussion 0
The net running experience can be had by that multi purpose app crunching calculator that ended up in everybody's pocket. Much to the dismay of math teachers world wide. With that in mind and my favorite cyberpunk novels, games and lore.
I bring you a simple relatively cheap project that's biggest contributor just buzzed a notification as you read this. Using any Android device with dex on board as the heart of the project. I quickly made use of the Bluetooth side of our smart devices by adding a folding keyboard with included touchpad mouse from eBay but can easily be found on aliexpress or the like.
It is my firm believe that a cyber deck should interface with the user through more than just tactile interaction. Therefore, I added the Nreal glasses and connected a camcorder hinge to make it a convertible if sorts. The last thing not added is a usb hub for charging and expanding my cyberdeck experience
-Unfortunately I can't add more detail due to lack of text
