The coil from Carl arrived and the first test look nice; a 4x2 round magnet glued on a 0.2mm thich silicon sheet moved very well when switching the coil;
So I decied a small pumped based in a set of tesla coils:
the
The test pump I drilled in an acrylic plate on my 3018 cnc Then mounting it together with M4 screws resulted in a nice pump pack; But the magnet did not really move at al. I could here a sound but I think the force was much to small to create a real pump ....
