What happened so far - Part 2.
A project log for Microfluidic Aquarium Sea Water Test
How to measure all important chemical micro substances with a cheap, DIY microfluidic test device. Research in progress - follow my journey.
bastelbausBastelBaus 09/18/2023 at 19:040 Comments
My second attemp was to move to micro valves. I will need normal off valves since the final apperture should be stable also when not supplying a voltage. I milled again channels (three at the same time, middle block) and put a silicon sheet in between (left). The top acrylic I had 3 inlets and 3 outlets. In the middle three inlets to control the valves.
The top plate I countersinked the control port of the valve a bit that the silicon could be sucked in.
As basic setup I used an Arduino Nano controlling a mini pressure pump (in vacuum mode) and a pneumatic valve (not shown in picture) and try to pump some water. The setup shown was one of some different tires I had.
Results; In general it worked .... a bit. The main problem were:
I think I need some more inspiration how to make it work. It should be possible this way, but I did not really understood the effect chains and how the design parameter influence the behavior exactly.
