The MFD (Multi-function display) is salvaged from an old laptop. It is not running GameGlass
, like so many others SimPits out there do. Mostly because I’m not a fan of touchscreens or vendor lock-in. There is also the little detail that GameGlass
is simply not available for my operating system and does not know about all the Space Pew Pew I usually do.
When I was evaluating what to use to program mine I was caught between the difficult choice to learn yet another fancy framework, like Raylib
, that would do OpenGL ES 2.0 without X11 on the Raspberry Pi, or OpenFrameworks
, or simply go with something I knew already.
In the end I just threw the might of my CoffeeLake at it and went with React
since most of the data was already available via Node-RED
over Websockets anyway. Also… Arwes
is just so cool (alpha version or not) 🤩 and I had some experience with it thanks to my Streaming Overlay
that I also wrote with Arwes
. Connecting it to Node-RED
was just a matter of installing Socket.IO
to transport the messages. I rewrote the whole thing for version 2 though because the code for version 1 was a very hacky mess and the older Arwes
version was deprecated. The core functionality is still the same though.
Originally posted at https://simpit.dev/version-2/mfd-software/
