I did some pew pew Nothing new under the sun but this time I recorded as first person. Or as first person as it gets. Strapped the cam to my headphones (so much weight!) and killed some pirates. Managed to edit this into a half decent demo of the home cockpit in the end (I had none of v2 for ED so far):
I also streamlined the plumbing pipelines in Node-RED. Basically any game specific code is moved to a separated telemetry flow until the respective data can be used in the unified plumbing flow to dump everything into proper channels:
