RPi display for my VF-1 inspired home cockpit panel
A project log for Primary Buffer Panel v2
A glorified DIY joystick controller with an LCD (‘MFD’) and plenty of RGB.
beko-pharmBeko Pharm 01/04/2025 at 18:070 Comments
Ok quick demo time. Got a dead cheap RPi display for the RaspberryPi (3A in this case). It has a touch screen and is even fast enough to play videos. Well, with whopping 480x320 only but that's good enough. I was always going to add a[nother] display in my "Primary Buffer Panel" 🤓 It was however not possible since the panel is still sitting on my desk and there was no space for the center part. I do have a ViperPit now though and I wonder if I can make the panels interchangeable!
