From the U-boot shell prompt we can explore the command options available to us using the help command. There is a lot for us to explore:
kiwi# help ? - alias for 'help' CmdPerformanceTest- gettime - Get the system executing time ac - set a new config to the bootargs base - print or set address offset bdinfo - print Board Info structure boot - boot default, i.e., run 'bootcmd' bootargs_set- Set info exchange and set to boot args. bootcheck- bootcheck - Do boot check bootd - boot default, i.e., run 'bootcmd' bootm - boot application image from memory bootp - boot image via network using BOOTP/TFTP protocol checkfile- check file exist in u disk,and set the partition. checkstr- check_str_resume cleanallenv- cleanall environment variables to persistent storage cmp - memory compare config2env- Set config to environment. config_raw_io- Config the target device for raw I/O coninfo - print console devices and information cp - memory copy crc32 - checksum calculation custar - do usb update from the specified file that is in usb. dbg - set debug message level. Default level is INFO dc - delete the specific cofig that is in the bootargs delay - delay time, time unit is ms dhcp - boot image via network using DHCP/TFTP protocol du - du - Disable UART ebist - PHY loopback test echo - echo args to console editenv - edit environment variable edump - EMAC Register settings dump eloopback- Long loopback test env - environment handling commands epd - emac power down estart - EMAC start ewavetest- EMAC wave test exit - exit script false - do nothing, unsuccessfully fatfilesize- fatfilesize - load binary file from a dos filesystem fatinfo - print information about filesystem fatload - load binary file from a dos filesystem fatls - list files in a directory (default /) fatpartload- fatpartload - load binary file from a dos filesystem fatwrite- fatwrite - write binary file to a dos filesystem filelist- Dump the file list. filelisttest- This command is only for file list test filepartload- load part of a file to RAM get_mmap- get memory info from supernova's mmap gettime - gettime - Get the system executing time go - start application at address 'addr' gpio - GPIO Command: help - print command description/usage if_boot_to_pm- if boot to PM iminfo - print header information for application image imxtract- extract a part of a multi-image initDbgLevel- Initial varaible 'dbgLevel' init_raw_io- init raw_io module itest - return true/false on integer compare kernelProtect- kernelProtect - Protect kernel kernelProtectBist- kernelProtectBist - Protect kernel bist led - See led commands loadb - load binary file over serial line (kermit mode) loadenv - loadenv - load env for nand loads - load S-Record file over serial line loadspi - load data from SPI loady - load binary file over serial line (ymodem mode) loop - infinite loop on address range m2e - Restore the address and len to env from supernova's mmap macaddr - setup EMAC MAC addr mbup - mboot upgrade md - memory display memtest - Get the performance of memory miuProtect- miuProtect - Protect miu mm - memory modify (auto-incrementing address) mscompress7- Compress or decompress lzma files msg - print string - msg [string] mstar - update kernal & root file system automatically by script file mtest - simple RAM read/write test mversion- show changelist - mversion mw - memory write (fill) nm - memory modify (constant address) nuttxProtect- nuttx Protect - Protect nuttx ota_zip_check- do OTA zip package check. ping - send ICMP ECHO_REQUEST to network host pm51 - pm51 command: pm51 [option] pmProtect- runtime pm Protect - Protect runtime PM pop_raw_io_config- pop raw_io last config printenv- print environment variables push_raw_io_config- push raw_io current config raw_io_status- get raw_io status raw_read- Read the raw datas that store in the target device Yo have to execute 'config_raw_io' before using this cmd raw_write- Write the raw datas that store in the target deviceYo have to execute 'config_raw_io' before using this cmd recovery_wipe_partition- do recovery wipe data or cache. reset - Perform RESET of the CPU riu - riu - riu command run - run commands in an environment variable sar - sar Command: saveenv - save environment variables to persistent storage setenv - set environment variables showtb - Show register command table. - showtb [stage] showvar - print local hushshell variables showversion- Show version sleep - delay execution for some time source - run script from memory spi - See SPI commands spi2usb - Read data from spi to usb spi_rdc - spi_rdc - SPI read code from SPI flash to DRAM spi_wrc - spi_wrc - SPI write code from DRAM to SPI flash test - minimal test like /bin/sh testmode- set testmode into bootargs. tftpboot- boot image via network using TFTP protocol true - do nothing, successfully udstar - Execute the script file that is stored in usb disk unlockcmi- unlock cmi transfer board - unlock update_mode- get/set update_mode updatemiureg- Call driver to update miu setting usb - USB sub-system usb2spi - write data from usb to spi usb_bin_check- do usb bin document check. usbboot - boot from USB device ustar - ustar - update kernal & root file system automatically by script file version - print monitor, compiler and linker version wdt_enable- wdt_enable n - set Watchdog timer to n secs
Looking at the version information we can confirm this is U-boot running on a MIPS platform:
kiwi# version U-Boot 2011.06-svn565 (Mar 01 2018 - 21:27:50) mips-linux-gnu-gcc (Sourcery G++ Lite 4.3-51) 4.3.2 GNU ld (Sourcery G++ Lite 4.3-51) 2.18.50.20080215
Running bdinfo we can see we have 256MiB RAM is mapped onto virtual address range 0x80000000 to 0x8FFFFFFF. We can also peek into this address space using the md command. Peeking into any address outside of this range (certainly the addresses I've tried) causes the board to crash.
kiwi# bdinfo boot_params = 0x88492E00 memstart = 0x80000000 memsize = 0x10000000 flashstart = 0x00000000 flashsize = 0xDEADBEEF flashoffset = 0x00000000 ethaddr = (not set) ip_addr = 87E52D7CI4 baudrate = 115200 bps
The flash information is clearly garbage, perhaps meant to be a decoy. Aside from the amusing hexspeak the flash is only 16MiB in size and flashsize=0xDEADBEEF is nonesense. Without a datasheet for this SoC it is difficult to understand the full memory map, there must be boot-ROM code somewhere, as well as various hardware registers. All we know so far is where the RAM resides. We don't yet know what the reset vector is.
Running printenv we can see the output of the U-boot environment variables:
kiwi# printenv
UARTOnOff=on
baudrate=115200
bootcmd=if mmc rescan ${mmcdev}; then if run loadbootscript; then run bootscript; else if run loaduimage; then run mmcboot; fi; fi; fi
bootdelay=0
bootscript=echo Running bootscript from mmc${mmcdev} ...; source ${loadaddr}
console=ttyS2,115200n8
loadaddr=0x82000000
loadbootscript=fatload mmc ${mmcdev} ${loadaddr} boot.scr
loaduimage=fatload mmc ${mmcdev} ${loadaddr} uImage
mmcargs=setenv bootargs console=${console} vram=${vram} root=${mmcroot} rootfstype=${mmcrootfstype}
mmcboot=echo Booting from mmc${mmcdev} ...; run mmcargs; bootm ${loadaddr}
mmcdev=0
mmcroot=/dev/mmcblk0p2 rw
mmcrootfstype=ext3 rootwait
osd_language=English
stderr=serial
stdin=serial
stdout=serial
ubispeedup=UBI
usbtty=cdc_acm
vram=16M
Environment size: 788/65532 bytes
Once again we can see misleading information here.... The bootcmd is bounded by an if statement which requires the command mmc rescan 0 to return success as a condition for the execution of the boot script or kernel image. Since mmc rescan 0 is not a valid command (according to help it doesn't appear in the list) this is not possible, and there is no alternative captured in the bootcmd for if this conditional statement fails. Furthermore there is no MMC/SD hardware on this board, it isn't possible to load from an MMC/SD based file system. Clearly the U-boot is booting something, so one must presume there is a hardcoded alternative boot command somewhere in the binary and this bootcmd environment variable is either another decoy, or a remnant from a previous development version.
Last updated 27th Oct 2023
sphaleron
