Design Overview
Also see the CC BY-NC-SA 4.0 license.
Project Introduction
The power module designed based on EA3036.The EA3036 is a 3CH buck power meanagement ic.The module can be used for multiple power supply applications.
Features
- 2.7V to 5.5V input voltag range
- 0.6V to Vin output voltage range
- Maximum Continuous Load Current: 2A (3CH total output power consumption must be less than 6W)
- For more features, please refer to the EA3036 datasheet
Project SCH
- Default parameter: 3.3V output for all three channels
- Change the output voltage by adjusting R1/R2, R4/R3, and R6/R5
- The C2、C5 and C8 is feedback loop regulation capacitor
Project PCB
- PCB design is compatible with DIP-2.54MM and Snap off hol
- Using Snap off hol design requires changing the top layer silk screen at the solder pad to a borde
MS-BOSS
lucy moglia
kerimil
