Direct embossing with a 3D printer
Emboss paper with a stylus attached to a 3D printer hot end
samSam
This is more an idea than project but not one I've seen online so here it is. I wanted a sheet of 1/50th scale brick paper for scale modeling but the model shop that has some is further than I feel like traveling and I dont want to wait for an online delivery, so I spent two days hacking a pen onto my printer. Brick papaer or wall card is just a card printed with a photo of a wall and the bricks are embossed.
The basic idea is to put something soft on the print bed and attach a pen to the hot end. then you use the printer as a plotter, the soft backing means that the pen leaves a deep mark in the paper.
I found with index cards I could get 2mm embossing by stepping down 0.5mm between layers.
first I tried to emboss individual bricks but that took forever so in stead i choose to deboss the morter between the bricks.
I wrote a quick python script (with excerpts from bobcncr's gcodesender.py) to easily generate brick patterns and interface with printer.
morter_gcode_send.py
basic script for interfacing with a marlin printer
py - 3.07 kB - 10/01/2023 at 09:32
Download
