A Hughes Space & Communications box, when reverse-engineered, seems to contain a dual-locked-oscillator FM signal generator, most likely used in a communications satellite for a microwave link somewhere in the 20-40 Ghz range:
https://www.eevblog.com/forum/projects/avionics-reverse-engineering-spacecraft-equipment/
