This large assembly only contains 3 MIL-STD-1553 serial channels, plus some counters. Surprising how much board space this used to take up! https://www.eevblog.com/forum/projects/avionics-teardown-engine-controller-boards/msg6143931/#msg6143931
A project log for Avionics + mil-spec teardowns
Reverse-engineering (mostly-)cheap eBay finds
