(20170326) (rev 20200524) The germanium inventory is there
So far, my silicon stocks are:
| Reference | Pol. | Ft(Hz) | U(V) | I(mA) | P(mW) | hFE | Fab | Qty |
| BC549C | NPN | 250M | 30 | 100 | 625 | 400..800 | CDIL | 14500 |
| BC550C | NPN | 250M | 45 | 100 | 625 | 400..800 | CDIL | 2000 |
| BC559C | PNP | 250M | 30 | 100 | 625 | 400..800 | CDIL | 5000 |
| MMBTH81 | PNP | 600M | 20 | 50 | 60 | Fairchild | 9000 | |
| KSP10/ MPSH10 | NPN | 650M | 25 | 350 | >60 | Fairchild | 1500 | |
| BF970 | PNP | 1G | 30 | 30 | Philips | 200 | ||
| BF1009SZ | N-ch | 1F | 9 | 10 | Infineon /Siemens | 30 | ||
| BFR96 | NPN | 3.2G | 15 | 75 | 170 | |||
| BFG425 | NPN | 3G? | 4.5 | 30 | 135 | NXP | 200 | |
| BFS480 | NPN | 7G? | 8 | 10 | 100 (30..200) | Infineon /Siemens | 4800 (+?) | |
| BFP420 | NPN | 25G | 4V | 60 | 200 | 60..130 | Infineon /Siemens | 100 (?) |
| 2N2369A | NPN | 500 | 15 | 200 | 360 | 20..120 | MOT(?) | 50 |
| PMBT2369 | NPN | 500 | 15 | 200 | 250 | 20..120 | Philips | 9000 |
Note: Ft (transition frequency) is often misleading:
- For the KSP10 it's given as the "Current Gain Bandwidth Product", the part is tested up to 100MHz only (with some plots up to 1GHz).
- The BFG425 is given as a "25GHz" part but the datasheet gives data tested up to 3GHz.
Why a PNP in the middle of the NPN ? Because of Complementary ECL : it must be possible to "pack" some gates together to form a circuit with alternating polarities, save some time and gates, and power too. For example the BFS480 could be paired with the MMBTH81 (though the speed disparity might not be a great choice)
I stumbled upon a stock of 2N2369, they might as well be included in this inventory "for scientific purposes". https://hackaday.io/project/8449-hackaday-ttlers/log/177581-my-own-try-at-a-ringo9-with-2n2369a uses some of them and I tested the 5ns rise time with few efforts (it can go faster with more efforts).
Note: some BC549C are already gone to contribute to #The Cardboard Computer :-)
20200521 : added the PMBT2369 and the BFP420
Yann Guidon / YGDES
Hi Yann, I am going to watch this project very closely :-)
Don't hold your breath too much, it's just a "polished" version of the relay and germanium versions ;-) Hence it will come 3rd, as the germanium version is more fascinating :-D
:-D
