Today I received the first prototype of the Sim7080G board I designed earlier. No problems with connection to AWS, the code is in the repo. I had to change pin definitions a little bit, but almost no changes aside from that. I used 'eu-central-1' AWS endpoint, perhaps it solved the problem I encountered earlier(described in the previous log).
Best regards,
Alex
