WiFi Manager for openWRT
An automatic switch between known APs.
This is a script and lua accompaniment for openWRT Chaos Calmer 15.05. This script will automatically switch between known APs on a list in order to keep a client connection to the internet. This project is a modified re-release of a defunct (read: non-functioning) script for an older version of openWRT.
I am no longer moving forward with this project as Openwrt supports multiple wireless access points with existing Travelmate package.
OpenWRT_wifiMgr_v0.3.5.zip
x-zip-compressed - 72.63 kB - 01/15/2017 at 08:21
Download
wifiMgr
wifimgr - 266.00 bytes - 01/15/2017 at 08:21
Download
apconnectionlog.htm
HyperText Markup Language (HTML) - 423.00 bytes - 01/06/2017 at 08:30
Download
wifiMgr.sh
Bourne Shell Script - 4.48 kB - 01/06/2017 at 08:30
Download
wifiMgrcfg
wifimgrcfg - 871.00 bytes - 01/06/2017 at 08:30
Download
View all 8 files
  • By Jove! I think he's got it!
    Daniel Roseman01/14/2017 at 07:52 0 comments
    So, it struck me as odd that the log would 'overflow' as it is a ring buffer in ram. It should be bulletproof. Well I was wrong in assuming that it was the log. And I think I may have my real answer. There is a known bug in init.d/network. When you invoke '/etc/init.d/network restart' you are playing russian roulette with the network interface. Sometimes the resources network needs in order to restart have not been released yet. Instead of waiting patiently for those resources, network crashes.
    This is the reason cron is able to revive the router.
    Read this for more details.
    There is a fix. It involves editing part of init.d/network. Just adding a section to bring the wifi network down before attempting to restart the network.
    I might just add a sanity check in the script that reboots the entire router when network crashes... Or just invoke 'wifi down' before restarting the network.
    Thoughts?
  • Mystery solved?
    Daniel Roseman01/14/2017 at 05:00 0 comments
    So, the messages I have put into the script seem to be overflowing the log buffer and killing the interface. Specifically, when you have none of the devices on the list to connect to. I would love to just snip that message, but I feel that it is a valuable tool for diagnostic should the router go into an unstable mode. I can confirm that it will come out of it's coma if you have a cron job to reset the router. I have made a cron job that resets the router (and subsequently erases the log for the previous day) once a day at 3am to ensure functionality. Should I snip the offending line of code, or does someone have a better idea (or better understanding)?
  • Sorting a small snag in the code...
    Daniel Roseman01/13/2017 at 09:48 0 comments
    So, after testing this out for about a week, I can say that this add-on will definitely crash your router about once a day... I think it has something to do with filling the log with messages. I'll get back to you... Going to do a logread from SSH and see where it dies...
  • Input and change request welcome
    Daniel Roseman01/06/2017 at 08:33 0 comments
    Please feel free to message me about things you've noted. Info to submit. Suggestions.
View all 4 project logs
