The project uses a highly modified version of the existing pi camera ROS node. The node was modified to publish bot a RAW grayscale image and a JPEG encoded image. This allow to use the RAW image for local processing and to publish the JPEG image to a ROS node connected to the WIFI network of the raspberry-pi with very low cpu-usage (the JPEG encoding is managed by the PI3 image processing pipeline).
piat.jonathan
nick.r.brewer
Brenda Armour
