ESP01-Riders :)
Common ground is in the power pack.
Tapped the power and ground going to the esp-01 for the servo to avoid even more spaghetti with a logic level converter.
Built the software in two parts. motors then servos and merged the software and dumped all the serial prints.
https://github.com/StormingMoose/ESP01-Riders
Plan to add an Xbox controller to this unit and make a wiring harness that is a bit more pretty than the spaghatti you see.
https://www.thingiverse.com/thing:5393551 is the Meccano mount for the ESP-01
Bought a Dupont wire kit with a crimp set and now have a use for some of those 8 hole units.
Need a new auto design, I've done a few different models, but this could get real little if you tried.
StormingMoose
Eytan
Roddy "Rags" Read
David
