Create your own affordable GPS/GNSS Base Station and Receiver with NTRIP server capabilities using the ESP32 and Unicorecomm UM980. This DIY guide walks you through hardware assembly, component connections, antenna selection, and firmware flashing. Elevate your GNSS applications with the UM980's superior performance. For the latest and most detailed instructions, refer to the original guide.
simeononsecurity
Catalin Sanda
Ishu1519
Tony
Thomas Büngener
Any luck getting GPIO 21 (R), GPIO 22 (G), and GPIO 23 (B) to work, i.e., indicating the connection status by the color that can be set for each client? For me, the RGB GPIOs are always high on an ESP32 NodeMCU. WiFi NTRIP Master hookup guide - ArduSimple
