I have finished installing all eight Tile Holder Buttons which means that the wiring is done.
I made sure that there was a good deal of slack in the wires coming from the buttons to ensure that the buttons were free to move when pressed.
I attached the top with four M3 x 6mm bolts to make sure that the buttons are secured while I start the testing.
