Noisy Regen Test
A project log for Yet Another MW Radio - The Audion
Another super simple medium wave radio. This time a Franklin Audion (synchronous detector).
agpcooperagp.cooper • 01/13/2017 at 06:30•0 Comments
Noisy Regen Test
Well I assembled and tested the noisy regen today:
Performance wise with the short antenna it was a little better than the first one. With a long antenna not as good. Selectivity was better (likely due to the higher input impedance as a result of lower collector currents).
Exciting? No. The reflex circuit was much better (but then I used a proper coil). Would I recommend it? No. Is it all the coil problem? No, I don't think so. To get an idea about how bad this receiver is, without the high gain audio amplifier you would not hear anything. I suspect a Ge diode followed by the same audio amplifier would work better!
Here is the layout:
Regards AlanX
