I implemented the inverse kinematics and inverse dynamics equations so that now the platform can be positioned at any orientation along a continuous trajectory. I rigged up a simple 8 point demo with the translational degrees of freedom controlled by ruckig (orientation remains fixed at perfectly level), to show that it is working!
Josh Pieper
