First working prototype
A project log for TIG Pedal for non-pedal TIG welders
This is a a simple solution to equip every welder, which does not have a pedal input, with a pedal to control the current.
cmaierhofercmaierhofer 10/13/2023 at 18:520 Comments
A first working prototype with a simple mount has been built and tested. It seems the components work together and the mechanic also works. ATM not the full range of 200 amps is available; I saw that there are servos that can handle about 270 degrees; that should work.
