First problem
A project log for TIG Pedal for non-pedal TIG welders
This is a a simple solution to equip every welder, which does not have a pedal input, with a pedal to control the current.
cmaierhofercmaierhofer 10/25/2023 at 21:570 Comments
After some more welding I saw that the Arduino basically stops executing it's program sometimes and starts again after a reset. I think the HF ignition is responsible for the problem. The first thing I want to try is to power the Arduino from a battery. Atm it is powered from a USB charger. If this doesn't help, I will need to invest some time in thinking about better shielding of cables and housing. Will keep you updated.
