I printed the layout of the mainboard holes, punshed, drilled and and tapped holes to mount teh mainboard as well as the alu frame.
A project log for Full Passive AMD Ryzen 7 7700x DIY build
DIY build using heatpipes and two massive 300mm x 235mm x 75mm ribbed cooler blocks to form a zero noise passive cooled PC
