Our final setup looks like this:
With a closer look at our wiring:
As you can see we added a buzzer which makes a small sound when you turn left or when you turn right (to let you know that you are in front of one of the motion sensors)
The turning left and turning right part of out project works.
However, our weight sensor stopped working although our code works; so the acceleration part of out project doesn't work.
