I find it useful to envision as many future requirements as I can think of. That way the architecture can be designed with future upgrades in mind, even if these features are never actually implemented.
- Support for multiple display sizes and types
- TFT LCD
- Character STN LCD modules
- Graphic STN LCD modules
- eInk displays
- OLED screens
- Analog dial gauges (via PWM)
- LED displays (bar graphs, 7 segment, matrix)
- Support for Android / iOS devices as additional graphical user interfaces and for internet access
- Smartphones
- Tablets
- Smartwatches
- Synthetic Vision System (SVS)
- Moving Map View
- Airports / landing strips
- Airspaces
- Current and predicted Weather
- Waypoints and path planning
- Other Airplanes in the area
- Via Automatic Dependent Surveillance - Broadcast (ADS-B)
- Via Low-Cost ISM-Band Transceiver (for friends in your group)
- Engine Monitoring (multiple engines)
- Revolution Counter (RPM)
- Hour Meter (Hobbs)
- Maintenance / service timer
- Exhaust Gas Temperatures (EGT)
- Cylinder Head Temperatures (CHT)
- Coolant Water Temperature (H20)
- Oil Temperature
- Oil Pressure
- Manifold Pressure
- Alternator Voltage
- Alternator Current
- Fuel Management (multiple fuel systems)
- Fuel Level
- Fuel Pressure
- Fuel Flow (Instantaneous, Average, Accumulated)
- Fuel Range / Endurance
- Fuel Pump Control
- Navigation Instruments
- Heading
- Magnetic Heading (compass)
- True Heading (GPS based)
- VHF Omni Directional Radio Range (VOR)
- Speed
- Air Speed (pitot tube)
- Ground Speed (GPS based)
- Vertical Speed Indicator (pressure differential)
- Vertical Speed Indicator (GPS altitude differential)
- Glide Ratio
- Altitude
- Barometric Altitude (user QNH setting)
- Flight Level (QNH=1013.2 hPa)
- True Altitude (GPS based)
- Radar Altimeter
- Height above runway (ultrasonic sensor)
- Attitude and Heading Reference System (AHRS)
- Artificial Horizon
- Inclinometer
- G-Force meter
- Angle Of Attack (AOA) Indicator
- Turn Coordinator
- Turn and Slip Indicator
- GPS Position Coordinates (multiple formats)
- Distance covered
- Flight Time
- Reporting point helper
- Distance and heading to nearest reporting point (e.g. 3 miles NE of XYZ) for radio position reports
- Waypoints management
- Route and waypoint editing
- Course Deviation Indicator (CDI)
- 3D Heading to next waypoint
- Vertical Distance to next waypoint
- Horizontal Distance to next waypoint
- Time to next waypoint
- Default waypoint: takeoff location
- Heading
- Flight Data Logging (black box)
- Visual and audible warnings (navigation, thresholds exceeded, etc)
- Interface with other Avionics
- Altitude encoder for Mode C Transponders
- Transponder Remote Control
- Intercom Remote Control
- Air Band Transceiver (Radio) Control
- Pilot Notes / Checklists / Frequencies
- Edit
- View
- Upload
- Download
- Aircraft Status and Control
- Battery Voltage
- Battery Current (charge / discharge)
- Flap position
- Landing gear
- Strobe light
- Headlight
- Heater control
- Heat Vest control
- Stopwatch / Countdown
- Density Altitude
- Ambient Air Temperature
- Date / Time (from GPS)
This list is by far not complete, but should give a good starting point for the detailed design.
