Besides obvious functionality of movement, switching to PuzzleBox32 Mini gives me:
- Higher resolution (32 bit vs 8 bit Architecture)
- Limit switches:
- Isolation of the limit switch from the controller board
- Power is supplied via the limit switch connectors
- Better noise resilience
- PWM/Enable output for Spindle control (gonna be converted to 0-10V externally)
- Aux port for mist control
Henrik Sorensen
