This is a small USB power equalizer bar with an integrated microphone. Different modes and color settings can be selected with push buttons on the rear side. There is also a version with an integrated battery.
The device is surprisingly well made. The PCB sits at the bottom of the casing with white light diffusing cavities on top. The bar is illuminated by 32 addressable RGB LEDs in 3528 form factor.
I close-up of an LED is shown above. This seems to be a "TX1812" based device, which currently seem to be the lowest cost WS2812 clones. They can be found from several "no name" suppliers.
