Received all components ordered, beginning soldering the pressure sensors with its different parts and cables.
![](https://cdn.hackaday.io/images/6616821704808201656.jpg)
Beginning printing of the box with exact measurements found on the user guide : HX-711 pressure sensor user guide. We also used this document to work out which cable goes with which pin. There is 4 main pins, that get soldered with each cable. Then there is 4 other pins that connect directly to the arduino.
Also started coding and setting up the pressure sensors to arduino code
