TSOC_PSoC4L - PSoC4 (Large) Embedded Module :
The TSOC_PSoC4L is a low cost, embeddable module featuring a PSoC4 "Large" device :
- 32-bit MCU Subsystem (48MHZ ARM Cortex-M0)
- USB Full-Speed Controller - 16 Endpoints
- Li-Po battery connector and integrated USB charger
- Programmable Analog Blocks (4 blocks)
- Programmable Digital Blocks (8 blocks)
- 3.3 Volt or 5.0 Volt Operation
- Serial Communication (3 Ports)
- Counter/Timers/PWMs (8 Ports)
- Battery Charge Status LED
- USER LED
- USER Pushbutton
- Optional 32Khz Oscillator for Real-Time Clock
- Optional High Precision Oscillator
- Optional FM24W256-G NVSRAM (32K Bytes Nonvolatile SRAM)
- Optional CAN (controller area network) Controller
- thingSoC Compliant Module
- Mikrobus Compatible Module
;-) Tom
If you find this project useful, please consider supporting our Crowd Funding campaign at
http://bit.ly/2kkKddJ
we could really use your help and support - thanks!
@PatternAgents
Pattern Agents
Chris Hamilton
Erik@EDrTech
f4drj
