The board schematics is available from the files tab here on Hackaday.
Here is the PoE-powered video streaming in action:
And upgraded version of the Esp32-Stick with Camera/Ethernet/Poe support based around the Esp32-S3 chip
Schematic_esp32-S3-POE-P-CAM_V.5.0.0_2024-03-12.pdfEsp32-Stick-PoE-P-Cam V5.0.0 schematicsAdobe Portable Document Format - 249.57 kB - 03/12/2024 at 19:56 |
Schematic_esp32-S3-POE-A-CAM_V5.0.0_2024-01-27.pdfEsp32-Stick-PoE-A-Cam V5.0.0 schematicsAdobe Portable Document Format - 269.79 kB - 01/27/2024 at 11:00 |
Schematic_esp32-S3-POE-P-CAM_2023-10-23.pdfEsp32-Stick-PoE-P-Cam V4.0.0 schematicsAdobe Portable Document Format - 240.47 kB - 10/26/2023 at 16:22 |
Schematic_esp32-S3-POE-A-CAM_2023-10-20.pdfEsp32-Stick-PoE-A-Cam V4.0.0 schematicsAdobe Portable Document Format - 278.55 kB - 10/26/2023 at 16:22 |
Schematic_esp32-S3-ETH-CAM_2023-10-23.pdfEsp32-Stick-Eth-Cam V4.0.0 schematicsAdobe Portable Document Format - 224.54 kB - 10/26/2023 at 16:22 |
The bigger batch has finally arrived and is now available for purchase on Tindie. Additionally, to make the boards more accessible, I've decided to launch an Easter sale!
Hello everyone, long time no see.
The year 2024 has recently begun and it's time to push the project a little further! I received many positive feedback about the boards and people seem to be satisfied, so I will be making bigger batch in February(100 pcs of PoE-A and PoE-P boards).
One customer pointed out to me that the PSRAM may be unavailable when using the Ethernet, because they share the same pins. In the newer version this bug will be fixed.
I also got the YAML(Thanks to my friend Vít Petrák) for ESPHome, you can check it out here. The YAML demonstrates the Ethernet and Camera usage and can help you to connect the board to Home Assistant.
Stay tuned!
Alex
Ton of features for one small board. Feels like you could get a lot of work done with something like this. Nice work!
