Today I learned to generate a .dxf of my keyboard plate layout and use KiCad to render that layout in 3D.
Since I'm using KLE for this key layout I was able to copy the raw data into the Swillkb Plate & Case Builder. There I specified the radius of the corners, the margin size, and where to create cutouts for the joystick and OLED screen. I'm not entirely sure on the dimensions of those cutouts, I'll be more accurate when the parts come in. I still need to add mounting holes, but this is a start to creating the plate out of PCB.
Mx. Jack Nelson
