This one took a bit of thinking, and several changes of mind between a) fitting a micro servo right next to the rudder and b) making a mechanical linkage actuated by a rod running forward under the rear deck into the main bay where everything else lives. In the end, it was tight, but the micro servo option worked out fine. I can still remove it if it ever fails or gets wet.
![](https://cdn.hackaday.io/images/3186721699694333360.jpg)
The rudder and prop shaft are now also glued in, and the hull filled and sealed, so we're pretty much ready for painting.
Before that though, I want to hook up the motor and ESC, and see if she floats!
