A few people have asked whether or not the Connection Machine miniature has enough room inside for a Raspberry Pi so here are a couple of photos showing the situation.
This is a shot of the two main parts of the body before I glue them together with a RPi inside to show that it does fit:
And here's a look at the rear of the glued-together body with an RPi inside. Those openings on the back are big enough for the Pi to pass inside as long as it is tilted 45 degrees.
So, yes you can fit a Pi fully inside.
Trevor Flowers
