Of course the first thing what to do when new PC components arrive is to build them together (picture left, only with boot SSD) and check if it is running. And yes, it was running :-). Next I took the cooler andcopied the micro-itx holes to the alluminium cooler with a printed schematic.
As corners I used 20x20mm Bosch profiles with 10cm length with M6 threads. For mainboard I mounted on small 3mm distance bolts.
Putting everything together it looked already quite satisfying and as lid I used a 6mm acrylic sheet I had laying around which I screwed onto the profiles.
