I am Back
I have been on holidays and busy working on a couple of other projects.
Anyway I fired up the CNC and made three more wooden slices for the modem case.
Just one more wooden slice and the strip-board to go.
I have to have a look at the strip-board layout and how I am going to route the USB cable.
Also some code to communicate to the host computer and to set the modem as originate or answer.
The other problem is that I will need to make a second modem to talk to!
The Modem Box
Here is the completed modem box (top view):
No iPhone:
Bottom view:
Disassembled:
So work remaining is to design the strip-board, the USB cable route and perhaps a varnish.
AlanX
