A Fabricobbled Signal Generator
A project log for AGC Preamp for Boondock Echo
Non-standard use cases sometimes need special treatment
dan-maloneyDan Maloney 11/08/2023 at 04:230 Comments
I don't have much test gear, so I need to make due with what I've got. In the end I used this glorious mess to generate a 1-kHz sine wave and send it to the scanner over-the-air:
The function generator sends a 1-kHz sine wave 30-mVpp out to the Baofeng mic jack over a 3.5-mm extension cable. The Baofeng is set to 146.420 MHz, a simplex frequency in the 2-meter band. I replaced the antenna with my Li'l Dummy dummy load, just to keep radiation to a minimum. I added that frequency to my scanner, and when I key up I get a nice pure tone out of the speaker. I also make sure I identify myself, just in case my signal is getting out of the shack.
So now I have a test signal. What I don't know is how hard to drive the Baofeng. I did some Googling and 30 mV p-p seems reasonable for an electret mic like the Baofeng uses, but it's just a guess. More research needed.
Next steps:
