Hi,
I have drawn a very simple, but easy to print, case for Walter. It allows you to easily test Walter as a stand-alone tracker device without exposing the bare board to much. You have space for all antenna's in the housing and there is also a spare hole to install an SMA pigtail if you want to use an external GNSS antenna. All design files are on Github: https://github.com/QuickSpot/walter-simple-housing
