technolomaniac says:2 hours ago
so no no...that'll stay
Garrett Mace says:2 hours ago
Inventor is still around, right? :D
BTW...I mentioned it, but now you can do non-modal commands like block select stuff
(I have an Inventor license too, I use it all the time)
oh yah, inventor is alive and well
ahh, nice
inventor is a fun tool. I really enjoy it. long before my time at autodesk. :)
They did successfully move away from the command line in it, though of course you still can
charliex says:2 hours ago
i'd still like to see non blockng ulp's but i realise that might break a lot of things
Teuniz says:2 hours ago
I get a bit scary when I hear "server side"...
I will get non-blocking ULPs if my life depends on it.
Jorge Garcia says:2 hours ago
I want to see non-blocking ulps that can accept mouse clicks. I'm with you Charlie
We will not use additions that require an internet connection.
Matt is already convinced
davedarko says:2 hours ago
could the "beep ON | OFF" get an OFF default and a GUI checkbox? that'd be great ;)
charliex: I'd like to see some kind of live scripting ability. triggered events, stuff that can help you while you work.
yep exactly, sometimes i fill in a ulp settings and i miss the target and have to redo it, usually when laying out circular pattern leds ;)
I mean, the ability to create it. Give tools to the ULP community and it'll be awesome
@Teuniz online / offline is interesting. I think the push is to of course handle licensing the autodesk way, but the desktop application will remain on the desktop until it makes sense to do otherwise.
that licensning model will require that you connect to retrieve a license but then you can merrily go on your way and use the SW.
and it will work in an offline mode with no data being pushed into the cloud
Sure....however, I will use whatever application is more reliable than the website we're using right now :)
(unless you want to do it...which means we should add that capability)
So, in future, we can't use Eagle anymore without an internet connection???
some stuff is just inherently better with a server side data model...like interfacing to mfg
Arsenijs says:2 hours ago
Teuniz, you should read what heš saying
you can. but you will need to connect to get a license.
I'd be OK with a combo of online or dongle license. If I need to work without internet (which happens) then there is at least a chance I didn't lose my dongle
after that, you can disconnect.
is eagle on your computer now.
and download it ;)
Internet connection will be required exactly once, from what I understand.
I have used Eagle at Burning Man to diagnose an art car controller PCB
we'll handle the timeout between successive logins. we set this to two weeks for Fusion 360 and nobody complained
I don't get just one connection
so it does require a successive login...but with a heartbeat of two weeks between requests for the token
online licensing is fine, but you just need the long time between checks or offline, since stuff like last month or so happens whenhalf the internet goes out
How about 52 weeks :D
it's pretty lax. and if we need to make a case for a longer heartbeat, I can do it.
Using internet to buy a license is ok. Requiring an internet connection in order to use that license is not.
You need to be able to hit the internet at least once every two weeks to keep the licensing system happy.
it helps the accountants sleep at night
Too many SaaS going belly up these days
Adobe and Autodesk disagree
So do Gimp and Kicad I guess
I don't like it.
@Teuniz sorry you feel that way, honestly. but the model of having your license shared across multiple machines requires something better than a license key or a license file.
I understand it though
2 hours ago
I don't like it either
yeah otherwise you end up captured ina vm thats sharewd all over, or on a chinse render farm if youre rendering software say
jarek319 says:2 hours ago
??? I've had a "portable" install of eagle 7.x on my thumbdrive that I use almost every day on an airgapped computer and havent had issues...
Professor Fartsparkles says:2 hours ago
I asked it on the spreadsheet but I think that thing isn't really used so I'm gonna ask again here.Can we expect to see some improvement in regards to importing and handling of bitmap and vector graphics files? So far it´is really pain to get logos and what not on your board without something getting really weird.
Eagle has been able to survive all those years. No need to to change the license system.
That's valid if you don't have a free service tier, which has been Eagle's way of marginalizing pirates
@Teuniz this is how much of the SW you already use is licensed. adobe. office. facebook. google products & services. free or not...this is a model that is replacing the license key.
and it's a way to ensure that when a customer pays for something, that only they use it and it doesnt go rogue. I would love to shelve the idea but piracy is a huge thing and we are giving away free licenses to students, startups, hobbyists, etc. already.
Apart from Gmail, we don't use any of them.
Engineers are not quite the same as graphic designers. I have a Macbook but it's from 2011, I'm not replacing it because it still works great. We get anxious when we contemplate not being able to do work
if the licenseing system ever goes away, we'll just hack it out anyway ;)
I have to go, thanks for the chat.
I agree it's a suboptimal biproduct of an unfair world. so if you can come up with a way to better protect software and fund the development of amazing tech, I promise you, I'm all ears.
I love Eagle and will continue to use it even after a licensing change
as in if the companuy goes bust
But will also learn how to use Kicad in case something happens
I'd say try it first, if it really isn't going to work for you then I'm sure you won't be alone
thanks @Garrett Mace ...and for the record, Hackday.io is cloud licensed.
alright guys...have to run!
I know...and I'm glad I don't use it for work because it's been down multiple times today
back online when I'm back at my desk...sorry about the ddos nonsense.
LD
:D
haahaha...ok, yah. shit. bad example.
yeah its still laggy
Thanks!
Later everyone
:D
thanks guys for coming!
yeah thanks guys, glad to see all the changes
DDOS a license server is not impossible
and of course, you'll see me here just about any other time too.
alexanderlang1980 says:2 hours ago
Thanks for the chat - Laters
Benoit Rapidel says:2 hours ago
Bye
so just ping me when you feel like it.
ok did you fix that bug in the rename of tracks yet?
after all, I sort of frequent this community ;)
ooh...which?
and WHY? ...ooh WHY? can I open a dialog with the name of a net and not edit it?
name a track and the overlay doesnt change in 7.7 windows
sorry...my one eagle rant for today.
that one is going to be fixed.
cool
Zoom in and out does it refresh?
ahh, ok...let me look into that. it should be fixed.
but Ill comfirm.
lemme check, im working in eagle at the moment
@Jorge Garcia let's be sure that's in the build.
yeah zoom refreshes it, you can tell when i'm wokring in ealge and chatting, since half the time i type the comamnd in to the chat window, so its always, ra
OK good, it's not bug. EAGLE only updates it when the screen needs to be redrawn like when you zoom in our out.
but we can fix that charlie
I'm always waggling the scroll wheel in eagle. large cursor (the only sensible choice) pukes pixels all over layout until refreshed
it should redraw on the exit
yeah it should redraw after a state change
For sure, I'm aware of the pixel puke. It's a similar issue.
I was going to try it...whoops Eagle crashed on my first pan
Garrett are you on a Mac?
like i can pan around and rename tracks, and they dont update til i zoom, but i might not zoom
Jorge: Yes
mac bug. fixed in a later beta on the eagle webstie.
it wasnt a full release, just that bug.
Awesome
When you open EAGLE. Resize the window a little before you start working. That should avoid the crash.
sorry - this is directed @charliex
Jorge I discovered that too, sometimes forget :)
ok
For pixel puke zoom in and out too clear
preview window for find? :)
Could you elaborate Charlie
if i want to find a component just to check something, it might be on a different sheet, a little popup showing it instead of switching to the sheet
just spitballing, havent thought it through
if you're still around though i am curious about the choice that when you rename a net/signal that the default is only to do that segment vs all sheet/globally? is that a normal approach.
charlie: it makes sense to me. A lot of design can be connecting nets by name rather than dragging all the lines across the sheet. I find myself renaming stubs to something different rather than wanting to change every net attached to it
technolomaniac says:an hour ago
@charliex I think we need both options
charliex says:an hour ago
yeah i just wondered what people felt about it, it seems like an odd default since somethings i end up with a signal being split in half and not spotting it. mostly curious, its rare to get direct input so i figured i'd ask
we should prompt you to do that locally if the user wants it
I think making big changes across sheets is scary without a prompt to scope the change
Garrett Mace says:an hour ago
fat nets with signal names embedded
yeah its the default i'm curious about, personally i'd rather have the default all versus the current segment only
but i get it, we all like different stuff, thats software for ya
Regarding the licensing stuff I want to make sure you understand...we get it...Autodesk is on board with putting in the dev hours to make these improvements, but they need to see a return. It's going to be OK, I'll keep using Eagle and any users you lose will probably be replaced by new ones as Eagle gets more popular. I have a small personal dislike of too many things going Cloud, but still, I get it and appreciate the work you're doing :)
yeah i still use my comfile board occasionally still ;)
Whoa there's a blast from the past. I haven't even kept up with them
yeah i bought a bunch of them from you way back , i think around 07 maybe
They are a good example of something that just gets it done. Not worrying so much about raw performance
yeah they were great, also good for teaching people with the ladder logic
ok thanks for the chat, time to go back to work...
todbot says:an hour ago
++ what Garrett said. I'm pleased to see all the effort Autodesk has put into the community. I too have been burned several times by cloud-connected products going non-functional when the company producing it goes away or stops caring. But I understand the desire to have connected products. And I'm eager to move to something significantly better than Eagle v6.6.0 :-)
Sophi Kravitz
