I tend to post my project design files and code on GitHub. I make use of open source software to get my projects done, so I figure it is only fair to make my stuff open source as well. That is, I use all kinds of free and open source programs to do the design and programming, so I make my finished stuff open source as well. I also do my best to follow the licensing requirements of the libraries I use.
Bigfoot is no exception.
I posted all the stuff I designed and all the information I gathered into the Bigfoot repository.
It's all there, though it is at the moment a bit of a mess. Schematic, PCB design, mechanical drawings for the hardware I built, datasheets for all the components I used, etc.
There are two versions of the Arduino software. There's the version I am currently using, which includes a PID controller and a PID autotuner, then there's a simple version that simply regulates power - it doesn't try to maintain the speed, it works like a standard sewing machine pedal.
The PCB design needs to be updated - I made a couple of small mistakes that I corrected when I assembled it, but I haven't gone back and corrected the KiCad files. There's a couple of pull down resistors missing, and there's a bleeder resistor missing on the 300VDC power supply. They are tacked on my PCB, but they aren't in the KiCad files.
Take a look. Leave a comment here or open an issue on the repository if there's something you need to know but can't find.
