The Blackstone Cube: Large Scale 3D Printer
Giant 500x500x600mm CoreXY 3D printer proof-of-concept made into reality.
One of the largest hobbyist 3D printers built, with parts printed from another printer!
Licensed under CC-BY-NC-SA 4
It's here, after 6 years of work!
The Blackstone Cube design began in 2018 (when I was in 7th grade) as a proof-of-concept 3D printer. Today, after an entire redesign, it has been successfully built.
Now, keep in mind: This is a work in progress!
I can't stop you from building it, but the benchy that I printed in the video turned out to have lots of artifacts!
Specifications:
  • 500mm (X) by 500mm (Y) by (around) 600mm (Z)
  • Fully CoreXY setup with 9mm 2GT Belts
  • Kinematic bed mount (allows for uneven Z heights)
  • Fully modular X Carriage
  • MGN12H linear rails
  • High temperature AC heated bed
  • Auto bed leveling
  • Auto Z align
  • Natively runs Marlin Firmware
Yes, those features all exist on the Blackstone Cube. At the time it was designed, it was fitted with all the best technologies!
Blackstone Cube Assembly_Frame Extrusions v7.step
Check this for individual frame extrusions requirements
step - 27.88 MB - 11/12/2023 at 20:27
Download
Blackstone Cube Assembly v103.zip
Overall step file for the entire printer.
x-zip-compressed - 15.80 MB - 11/12/2023 at 20:26
Download
  • 1 × Aluminum Extrusions (2020 and 2040 European) See Blackstone Cube_Frame Extrusions.step for more information
  • Extruder Assembly
    Xieshi Zhang11/12/2023 at 20:55 0 comments
    The extruder assembly is also fully modular.
  • Kinematic Coupling
    Xieshi Zhang11/12/2023 at 20:50 0 comments
    The printer uses Kelvin Coupling, as demonstrated here (credit to Wikipedia)
    A total of six contact points is required for kinematic coupling. The bed mount emulates that using magnets.
    Point 1 (technically infinite points, but it is to emulate the three point inverted pyramid):
    Point 2 (2 points):
    Point 3 (1 point):
  • Work In Progress!
    Xieshi Zhang11/12/2023 at 20:29 0 comments
    This project is WIP. More updates coming soon!
View all 3 project logs
  • 1
    "Complete" Instructions
    I have made an animation that goes over the basics of how to assemble the project, but the Y axis and X axis assemblies need more details.
View all instructions
Peabody1929 wrote 11/13/2023 at 17:48 point
Have you checked the tolerance for the "flatness" of the extrusions the print head rides on?
Xieshi Zhang wrote 11/14/2023 at 06:12 point
I have not checked that, but I'd imagine the extrusion itself is relatively straight, plus the X carriage rides on a linear rail.
The extrusion however does ride on 3D printed carriages, so I assume there would be some deviation in leveling, but that's hopefully rectified by auto Z leveling with the 3 Z screws.
