October 30, 2023
The project is progressing faster than I had anticipated; by around November 30th, we had already started connecting the modules physically. In terms of code, each module is connected to an Arduino. The goal is to interconnect all the modules with a single Arduino to create interactions among them. This means that in the case where the modules are not connected, when we finish all the modules, how does the timer know when to stop, and how can we be sure that all the modules have been successfully completed? To address this, we are using an Arduino Mega with more input/output capabilities, allowing us to connect everything together. As of this date, the ring LED and LCD modules were already interconnected.
