Today I installed the temperature regulator. It wasn't that difficult, given that I dry-ran it first. I drilled holes around the square outline of the temperature regulator, and it popped right in. There is plenty of space for the countdown timer.
It's a bit of a mess now. There's no point tidying it up now, because some other components will still be added. But here's an idea of how it will work.
From the front the controller looks more businesslike, with the actual temperature in red, and the programmed temperature in green. A little green LED shows that the SSR is switched on.
Here are some preliminary temperature measurements:
Time | Temperature (degrees Celsius) |
0 | 30 |
30 min | 45 |
60 min | 60 |
90 min | 60 |
I'd like the temperature to be a get a big higher than 60 degrees, 60 is already in the range to be useful as a sauna.
Bibliographic Entry | Result (w/surrounding text) | Standardized Result |
"Sauna." World Book 2005 Ed. | "In a sauna, stones are heated on top of a furnace. The temperature in the room ranges from 176 to 212°F (80 to 100°C)." | 80–100°C |
Avalon [pdf]. Electric Sauna Heater Operator's Manual. | If sauna heater operates, but sauna room does not come up to sauna temperature (160–185 ° normal Sauna temperature) | 71–85°C |
SaunaGen [pdf]. InfraRed Sauna Operator Manual. 2004. | "Set the temperature and time to a comfortable level, normally, 30 minutes at 49 °C." | 49 °C |
The Finnish Sauna Society. 2004. | "In the old smoke saunas the temperature varied from about 50 to 75°C (122 to 167°F)." | 50–75°C |
"The recommendation now is 80–90°C (176–194°F) with moderate humidity, but in many saunas today the temperature exceeds 100°C (212°F), at least at the beginning." | 80–90°C >100°C |
http://hypertextbook.com/facts/2005/HimtangWong.shtml
Once I've cladded the door with cedar the temperature should get higher, because now there is a 1 cm gap all along the side of the door from which heat escapes.
