The TSOC_ESP32S is a new radio module that supports both Wi-Fi and Bluetooth based on the ESP-32S radio from Espressif Systems. It is designed to be used either as a standalone module, or as a radio peripheral for other thingSoC processor modules. It is compatible with both the thingSoC module standard as well as the Mikrobus standard.
The ESP32 can perform as a complete standalone system or as a slave device to a host MCU to reduce communication stack overhead on the main application processor. The ESP32 can interface with other systems to provide Wi-Fi and Bluetooth functionality through the SPI / SDIO or I2C / UART interfaces.
;-) Tom
If you find this project useful, please consider supporting our Crowd Funding campaign at
http://bit.ly/2kkKddJ
we could really use your help and support - thanks!
@PatternAgents
Pattern Agents
Åke Hedman
AVR
