Finally I have something that works!
For now I can only connect via usb serial, and use the pheripheral bus, a/d and d/a converters. the I2C bus is protocol is still not implemented, and the FT245 interface needs to be implemented as well.
A project log for PC general purpose interface
A general purpose interface PC interface that should be able to give a regular pc I/O interfaces that are commonly found on MCU-s.
