The PCB arrived from OSHPark, and it works. You can order it at: https://oshpark.com/shared_projects/J8a9MVbO
I'm not happy with the buttons -- I used some cheap SMD buttons that I had on hand, but they are not really designed for being pushed directly by fingers. I might try gluing something on top of them, so they work better.
I used a chip socket for the chip, and the whole thing is rather high. In the future, I would probably use a different chip, in SMD version, and maybe even put it on the bottom.
All in all, it works well enough and I'm quite happy with it.
now remove all the headers, add the LCD shield and a LiPo shield, swap the dip to a soic footprint and make a sweet tiny little "gameboy" :) or at least stack them and take a picture of it :)
I really like the form and flow of this board!
Yeah, that's the direction I'm going, slowly, but the hard part is the software. So in the mean time I make the parts I need for it as separate things, re-usable for other stuff in case I fail miserably. If I ever pull it off, I will make a proper PCB.
