Running same coax to 5v relays.
Separate grounds, planning to switch single ended/differential
Unleaded started appearing all over the place
Identified, fixed
clingFilm+rubberBand
Attaching balanced microphone cables between relays & ADC connector, to make it more flexible and less fragile than coax (no buffer this time) AC/DC caps soldered on the other side
ADC DIP sockets, some headers, connections & secret markings :S
Something is brewing, picking up noise, might be relays
With faster ADCs will be making proper PCBs this is just some playtime
https://hackaday.io/project/21480-ldr-pot-making-matching-plotting
