Everything going on plan
A project log for Answer or Die
The final challenge before you can escape of the room
aliaAélia 01/12/2024 at 09:580 Comments
30/11/2023
We found some codes that shows where the touch on the screen is detected
https://streamable.com/4xctd3
Now we will connect this screen with the ring light and the digital touch.
And tadam
Before clicking on the next link be carefull, the light is a little bit agressive
https://streamable.com/bw3zgl
Now we need to complete the most difficult codes, we need to code our screen so it shows questions and answer, but it also had to react when we click on the answers. We also wants the ring light to act like a timer, and to go red or green (if the answer is true or false).
