07/12/2023 - 14/12/2023
The screen touch is hard to make it work
But we did it !
The screen touch AND the ring light go on when the digital touch is touch
But we need the screen touch to show questions and answer, so let's try to make it post something
We also made a code for the ring light, to turn it into a timer for each questions. It start with all the led and every seconds (not sur of the timing) one led go off, and when there is no more light, the timer is finished.
