Main memory increased from 2K to 64K words for the PleX ISA. This was part of an upgrade exercise using re-tracked PCBs, and was the final planned hardware change. Future updates will be firmware-only.
Floating point functions added to PleX . This has not been rigorously tested yet, apart from running Lunar Lander :) but any fixes will only require firmware updates.
Phil Tipping
