Create new custom tips or repair old tips that are corroded
See the instructables link above if more context is needed. These are the basic steps I took after tweaking that guide for my setup.
In the beginning you may want to check the status of the plating every 15 or 30min. If you see black soot, this is some kind of contamination (not sure if my nickel strip was not pure or it was from something else, do not allow any alligator clip or any other metal to be submerged in the vinegar). If you see its not plating evenly, you can remove and clean the areas that are not plating, carefully scrape or sand, then wipe and re-submerge. Maybe with better cleaning methods the plating would be more even, will keep trying.
In the beginning voltage in a small cup with items ~2cm apart was ~2V then it slowly increased with time. You can try higher voltages and currents, but these low numbers should improve the quality.
